Question about Kodak EasyShare Z1275 Digital Camera
Screen stays black
On a z1275,viewer screen is black.If I press button to take picture,the flash flashes but at no time can I see anything in viewer screen.I've tried all the normal battery and restart stuff.I can see all the words and symbols and messages that normally show.
    Problem Solver:
  • 6 Answers
Dear it has nothing to do with on and off its simply a setting problem
Posted on Jun 10, 2009
  • Anonymous Jun 10, 2009
    dear it has nothing to do with on and off its simply a setting problem
The same thing happened to my camera. The memory card was bad - I switched to a new one and the camera worked perfectly after that.
Posted on Jun 27, 2009
6ya staff
SOURCE:
Television stuck on black philips screen will not do anything except flash off and back on to same black philips screen.
Sounds like the media/main board is going out. You can change those out really easy with just a screw driver.
Check ebay with your part number off the board. Start with you tv model number and the the BOARD part number. Alot of board look alike but there aren't.
Also..
shopjimmy.com is a good place.
Good Luck.
Sep 11, 2015 | Philips Televison & Video
The viewer of my canon A620 is blank when I turn on the camera to take a picture
Press the DICP button 2 - 3 time and see the LCD turning on or not. Let me know.
Aug 07, 2012 | Canon PowerShot A620 Digital Camera
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
Apparently takes pictures ... but black out the screen .... if you turn on and everything but can not see anything ... Sorry about my English
I see nothing on the monitor screen when I want to capture a picture. The screen monitor remaind black but I can capture new pictures. when I press the play button, I can't see the picture. When I retreive the picture from the camera to a computer, I realize the picture is black and I can't distinguish anything.
But when I introduce the good picture from my computer to the Digital Camera, from the Sceen Monitor, I can visualize only the good picture I introduce in mysefl.
The flash is working properly, the on/Off button is ok, the lens appear to be normal.
My Digital Camera is Casio EX-S880 EXILIM
Jan 29, 2010 | Casio Exilim EX-S880 Digital Camera
D80-viewer and display stay black, the flash
If your camera got moisture inside and you turned it on before it had a chance to completely dry (usually takes several days) you may have caused a short circuit.
Dec 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Jun 15, 2009 | Acer Aspire One PC Notebook
Mogul Screen black
Press the soft reset button located right under the SD mini memory card its a small hole just press there with your stylus (pen)
Oct 26, 2008 | HTC PPC-6800 Smartphone
G9 flash
My flash doesnt work either. Holding the flash button down doesnt do anything either (in program mode)
Apr 08, 2008 | Canon PowerShot G9 Digital Camera
Black viewer and black photos
THE MOST LIKELY REASON FOR THIS COULD BE EITHER THE SHUTTER IS NOT OPENING(IN THIS CASE WHEN YOU HALF PRESS THE CLICK BUTTON YOU SEE SOME SORT OF SNOWY PICTURE )IF NOT THEN THE CCD HAS GONE FAULTY AND IN BOTH THE CASES THE HARDWARE NEEDS TO BE CHECKED THERE IS NOTHING YOU CAN DO ABOUT IT YOURSELF
Nov 17, 2007 | Fuji FinePix F20 Digital Camera
No picture, however there is sound
Is this set hooked to cable? Is there a cable or satellite box? When you press the menu button, do you see the menu on screen? Do you see anything on the screen, such as snow, or is it completely black? If the signal is OK and the TV has no picture at all, the red LED on the front of the set should be flashing a certain number of times. If the LED is flashing, the computer has detected a problem in the set and shut the picture off. If this is the case, there is no way for you to bring the picture back by pressing buttons. The number of times the LED flashes is the computer's way of displaying exactly why there is no picture. The set should then be serviced by a qualified tech familiar with Sony TV's. If the LED is not flashing and the menu comes up on screen, check your signal source. If you are using a cable or satellite box, that box could be bad, and if you are using RCA jacks, the yellow (video) wire could be bad or pulled out.
Aug 20, 2007 | Sony KV-32XBR250 TV
Kodak EasyShare Z1275 Digital Camera Logo
224 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
