Question about Linksys Wireless-G WRT54G Router
Problem sending email using Outlook 2010 on a PC and Linksys wireless network
I have a WRT54Gv2.2 wireless router. Recently I became unable to send email from my PC on all three of my Outlook 2010 email accounts. I can receive in Outlook with no problem but cannot send. I also have 3 Apple devices, iPhone, iPad and MacBook that connect on the same wireless router and can send email just fine using the Apple email utility. Any suggestions?
    Novelist:
    Scholar:
  • 192 Answers
I doubt the router has anything to do with the problem. most likely culprit is a pop server (handles incomming email). check with your email provider to see if they changed servers...
have you made any changes to your router or firewall? i guess it could be a port that got closed that your email was using
eh, here is a usefull website shows server names and ports used
http://www.arclab.com/products/amlc/list-of-smtp-and-pop3-servers-mailserver-list.html
Posted on Nov 21, 2013
6ya staff
SOURCE:
Anonymous
  • 192 Answers
SOURCE: wireless WRT54GX2 keep getting message "unable to connect to..
Replace it with a new one.
Posted on Jan 12, 2009
Anonymous
  • 9 Answers
SOURCE: Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Posted on May 01, 2009
govinda123
Prashant M
  • 2277 Answers
SOURCE: I have a linksys wrt160n wireless router,,
Is there any computer connected to the router ?
If not then connect the computer to the router. If you are connecting a wireless computer then disable the wireless connection on the computer. open the set up page of the router. change the wireless network name to something different that you never used before. change the standard channel to 11. save the settings. Try to connect to the wireless network. Check if you see the new network name ? If you see the new then try t connect and see if that works.
This router WRT160N has issues with the firmware.
Upgrade the firmware of the router. power cycle the router.
Click here for more information about router and network
Posted on Feb 28, 2010
Victor Rodriguez
  • 19 Answers
SOURCE: I'm trying to connect a
I had an iPAD and it worked right off with my wrt54GS, so I'm not exactly sure what the solution is, but you can try this.
Problem A:
-iPAD is looking for 802.11 "N" network and your router is A/B/G compatible only.
Solution A:
-Change your iPAD network settings to accept 802.11A/B/G or at least 802/11G WiFi signals.
Problem B:
router is set to only use 802.11A/B vs using multi-band B/G or even G only. NOTE: your router does not broadcast 802.11N signals so you must find a common wireless band to broadcast at. In this case 802.11G should work fine.
Solution B:
Assuming it's been previously set up (as stated) and you did not change most of the default settings on your router, aside from the password and security stuff...do the following via internet explorer or your preferred web browser:
-type 192.168.1.1 (or your routers IP) in your address bar to bring up the routers user interface
-Default user name is "admin" and password is "admin". You may be able to leave the user name blank and just type in the password section to access the router user interface. Again, you must know your password to access the router. NOTE...If "admin" worked, you better change that while you're in there.
-Once you're in, find the tab that sets the broadcasting protocol and make sure it's set to multi band 802.11A/B/G. IF, you're sure everything on your network is at least G speed, than set it as G only. A/B are old protocols and for the most part are not that heavily used. If you can go with at least G only speeds, than do it.
-Try and find your router again
I'm sure the iPAD works on wireless G networks, so that's why I say G will work.
Be sure to PRINT your settings and tape them to the bottom of the router so you don't forget, otherwise you'll have to reset the router and do it all again when you need to add something to the network.
Good luck.
Posted on Jan 11, 2011
flores136959
Daniel Flores
  • 215 Answers
SOURCE: I have the need to connect a Linksys WRT45G router
delet old enternet connection then rescan new enternet connection on router.
Posted on Feb 28, 2011
Changed my pasword yesterday and now i cant recieve or sned email. microsoft outlook says its a prrobblem with gmail account email address marvalovesmommy@gmail.com
You would also need to enter the new password in Outlook, if you use that to send email. Here is a guide how to to that:
http://support.microsoft.com/kb/2697421
What version of Outlook are you using?
Jan 16, 2014 | Computers & Internet
Sending e-mail on iPhone
What error message do you get when you try to send?
May 01, 2008 | Apple iPhone Smartphone
I have set up my Gmail so that my emails can be sent and recvd through Outlook 2007. I can receive but iam unable to send mail.
Verify your account settings in Outlook. you should have Outgoing mail server (SMTP) set as smtp.gmail.com
you can access account settings from File menu
Mar 15, 2011 | Computers & Internet
Unable to send emails but able to surf internet.
you have to set up where outlook is sending the mail IE: pop3, or stmp @ whatever your internet provider is
Jul 12, 2009 | D-Link DIR-625 (790069292637) Wireless...
Microsoft outlook
i am unable to send an email thru my outlook inspite of creating an account. i
Nov 09, 2008 | Microsoft Outlook 2003 for PC
Unable to send email in outlook 2003
check the mail settings for receiving and sending in tme mail options i think sending mail setting is wrong
Apr 23, 2008 | Microsoft Windows XP Professional With...
Sending email messages
this doesnt make sense as you wouldn't be able to send or receive. If you ave an antivirus programme check it's not scanning your message then putting it in the outbox. If you have changed your service provider recently but kept your old e mail address then the smtp settings are incorrect in your email send settings and may also require server authentication, although your pop3 receiving account may not need to change.
Sep 12, 2007 | 2wire 1800HG Router (RG1800HG00)
Send/Receive Mail with iPAQ
Did you select your account from the Accounts menu?
Sep 14, 2005 | HP iPAQ HX2415 Pocket PC
Linksys Wireless-G WRT54G Router Logo
79 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
