LG KU990 Viewty Logo
Anonymous Posted on May 06, 2009
HOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MOBILE PHONE SHOP HAS FAILED TO BE ABLE TO RE FLASH THE FIRM WARE PLEASE HELP
I have an lg ku990 and i have got the yellow refreshing screen i have tacken it to my local phone shop to re flash the firmware but the phone would not accept it can u help
Anonymous
Level 2:
Sniper:
  • Expert 65 Answers
  • Posted on May 08, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
65
Questions
0
Helped
65346
Points
176
HOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MO - a2ee4a7.gif LG_Authority
conect your phone with the usb port.
start in windows the program EFS MEDIA BUILDER by AKOM1976.
select connecton and after that you choose efs explorer select connection.
Now you see the files on your phone
maye there is a folder named as TOTO
be sure that this folder is on your phone!!!
If it does delete the folder named as LGAPP
after that rename the folder named TOTO to LGAPP
richt click and choose refresh.
now exit the efs program.
Turn your phone off and then after a few seconds on
the phone will startup normaly as always and its normal asual.
I hope this will work or you have to back up with the LGMDP euro
an after that choose restore and choose the image file *.nv2
This will work!
you can try a software update at http://nl.lgmobile.com/web/web.product.manualSoftwareRF.laf
This software update is at your own risk.
Choose your model of your mobile phone and download it.
Fallow the instructions by the software update be patience
if you don't see anything it take a few moments.
Comment posted on May 04, 2009 No you have to see that the folder already exist on your phone
LGAPP and a nother folder TOTO if the phone starts up and you didn't switch the folder it make a new folder LGAPP without the programs so all the folders in the folder LGAPP are emty.
So thats why you have to be sure that the folder TOTO is already exist on your phone.
And if you have a backup of the folder TOTO you can check if the maps are empty or not.
These files have to be in the map toto on your pc.
These are the file names that is logged by EFS explorer, you can see the folder names and the files that are in the folder map exist
Check if these file are located in the folders of your phone if not
delete the emty folder LGAPP and make a new folder named TOTO open that folder.
Now read the files that is on your pc in the map TOTO.
This folder have to be the files in it and doesn't suppose to be empty.
The files you need to see on your phone with EFS explorer looks like this:
LGAPP
LGAPPCommon
LGAPPDRM
LGAPPDRMCERT
LGAPPDRMCERTCERT
LGAPPDRMCERTCERTdevelopcert.cer
LGAPPDRMCERTCERTdevicecacert.cer
LGAPPDRMCERTCERTdevicecert.cer
LGAPPDRMCERTCERTdevicepkey.cer
LGAPPDRMCERTCERT ootcert.cer
LGAPPDRMCERTcmla
LGAPPDRMCERTcmladevicecacert.cer
LGAPPDRMCERTcmladevicecert.cer
LGAPPDRMCERTcmladevicepkey.cer
LGAPPDRMCERTcmla ootcert.cer
LGAPPDRMDPRO
LGAPPDRMDRMCERTTYPE.TXT
LGAPPDRMID
LGAPPDRMIDSYS
LGAPPDRMISAMDB
LGAPPDRMISAMDBCertDB.bin
LGAPPDRMISAMDBCertDBKey_CTYPE.bin
Etc.
[ File Renamed ] LGAPP->TOTO
These files are on the pc:
TOTO
TOTOCommon
TOTODRM
TOTODRMCERT
TOTODRMCERTCERT
TOTODRMCERTCERTdevelopcert.cer
TOTODRMCERTCERTdevicecacert.cer
TOTODRMCERTCERTdevicecert.cer
TOTODRMCERTCERTdevicepkey.cer
TOTODRMCERTCERT ootcert.cer
TOTODRMCERTcmla
TOTODRMCERTcmladevicecacert.cer
TOTODRMCERTcmladevicecert.cer
TOTODRMCERTcmladevicepkey.cer
TOTODRMCERTcmla ootcert.cer
TOTODRMDPRO
TOTODRMDRMCERTTYPE.TXT
TOTODRMID
TOTODRMIDSYS
TOTODRMISAMDB
TOTODRMISAMDBCertDB.bin
TOTODRMISAMDBCertDBKey_CTYPE.bin
TOTODRMISAMDBDCtxDB.bin
TOTODRMISAMDBDCtxDBKey_DID.bin
Etc.
and its fine to have these as my back up.
If your folder LGAPP on the fone is emty don't worry write the files from your pc to the phone Make a folder named TOTO.
and write all the files include the foleders in to TOTO at your phone.
When you fineshed. Rename LGAPP >> XLGAPP
Rename TOTO >> LGAPP.
Delete the folder XLGAPP.
Refresh and disconnect and you will see the phone startsup in
a normal mode. As you can see I delete th folder LGAPP that wHOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MO - 4f0b046.pngmg src="/uploads/images/4f0b046.png" alt="4f0b046.png" class="h_mi" />
Now I rHOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MO - 391fe7d.pngder that is back it up on my pc to the phone.
Now when its finished I renane that folder to LHOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MO - 52dbd8e.png4843641.png
When yo finished diconnect the phone by clicking disconnect.
So the phone start automatical again and now its running in norma
mode asual. I hope this will work for you.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
11787
Points
9
Flash using original firmware plus network, ie network phone was locked to when bought. Good luck
My lg ku990 viewty mobile phone has come up on the screen totally yellow and says in the top left corner REFRESHING i have tryed turning it off and unplugging the battery but it makes no difference! i have...
Hi, read the sections on the fallowing links.
But keep in mind that you've the software do his work and wait cause this process take up to
1 hour and 30 min. As you can see what EFS MEDIA BUILDER by AKOM1976 do is read the phone
then you will see a map that you have to rename for the secret switch! There is a secret switch to see
the hidden folders. The map LGAP has to rename to TOTO and when finished vice-versa.
Be patient when re-flash the phone when its ready it show a yellow screen but don't do anything just
wait!!!!! At that time the EFS MEDIA BUILDER is unpacking the files and when the process is done
the phone restart again and install the files after that when it is ready the phone starts up with a brand new software and show the welcome and configuration screen for the time, date and screen settings as it came from the factory.
Read the links below and fallow the steps. This time your phone will be alive!
http://www.fixya.com/support/t2141371-screen_broken_cannot_get_contacts_ku990
http://www.fixya.com/support/t1793053-lg_ku990_yellow_sreen
Henk®Muskita©2010.
1helpful
4answers
Yellow refreshing screen problem
You can better visit me and see the results of my solution.
There is one of them it can fix your problem and I am sure you
will find the answer!
Take a look at:
You'll fix your phone be patience and fallow the instructions!
Best regards:
Henk®Muskita© 2009.
Yellow refreshing screenon lg viewty what is this and how can i get my phone working again
Look at this issue: My lg ku990 has yellow sreen.
Answer:
I am sure this will fix your yellow screen that coms up on the start.
Read and take a lot of patience when you do the job.
I am sure thhis will help you out!
Best regard:
Henk®Muskita© 2009.
2helpful
Lg viewty yellow refreshing screen
you need to reflash it , you can either take it to a mobile repair shop or attemt to find the firmware yourself
1helpful
Yellow refreshing screen on my ku990
i had the same thing happen to my mobile you need a new firmware file use v10j it can be found on my great phone .com but i found the easyest way to find this is to google it and ask googl were can i get firmware v10j i thik the first answer is a link to mygreat phone ,com link to it and download this firmware next you need the flash software wich is LGMDP download this bit of software you need the usb lead for the next bit open the LGMDP prog select the the one that ses open you have a choice of us open or euro or h3g nowwhen you connect your mobile you should get a screen come up with connect at the bottom left hit it now you should get a screen with a load of empty spaces with a brouse button at the end hit the first brouse button in the list . now you need to go to the place were you saved you firmware v10j click on this file it should fill in all or every 1 except for media and modual and that will be in the same firmware file under others when you have done that you wiil get a list saying true and 1 should say faulse i think at the bottom it should say confirm hit it your mobile should to be firmware flashed this shold take about 20 mins PS the little blue box should say normal mode if it said emergency come back to me
6helpful
6answers
iyourfatherl
maybe this will work.
This will work!
My lg ku990 has stoppoed working propberly as the screen as gone yellow and the only word it says is refreshing
Hi cutekid327, this sounds like a technical issue. The only option is to take it to a phone shop or send it off to a phone manufacturer.
Thanks.
1helpful
2answers
Yellow screen
Dude that's simple but you need to have the sofware back up to reflash your phone in other words reinstall the whole system back on the phone. But how come you don't have a back up since you said that you got a yellow screen bc you were making a back up. Anyways, I did the same thing to hack my Viwety and I had no problems, but since i cannot fix it for you I can only point you in the right direction... go here for more information http://www.mygreatphone.com/forum/modifications-hacking/1543-firmware-flash-bricked-handsets-v10a-only-no-noobs.html
Do a little research and you'll find what you need here
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
