http://www.hifi-remote.com/ofa/codes-tv.shtml#tvIf none of the codes work then we have two other solutions:
1. Searching For Your CodeIf you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
- PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
- PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
- ENTER 9-9-1 (two blinks on the remote)
- ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
- When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the originalLine up your original remote and the head-to-head before completing thefollowing steps.
- PRESS and HOLD the SETUP button until the red LED flashes twice.
- PRESS 9 - 7 - 5, the red LED will flash twice.
- PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
- PRESS the button that will receive the learned function, the LED will flash rapidly.
- PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#deviceHope that helps! Should you have any further questions,please feel free to post them here.
Television
Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional):
We could not find an exact match, we think this code will work. 10054
Setup Instructions · Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
lost booklet codes
I have an rca universal remote and I want to program it to my sharp tv & i 4got the code
same problem,no instructions,need to reprogram
I have a control that is very simalar to the one mentioned, my grandson knocked off the bed and came apart i put together and it worked a couple of days but was slow then I replaced the batteries and now it does not work the red indicator light still works, when I input the codes it just stays lit, but when I input 1198 and 1199 the light blinks, but when you try to turn it off and on it does not work.
batteries are you in rca dvd remote red lights flash but i does not turn on maybe the code has been deprogrammed
it is an RCA universal remote control, but I do not know the code to reinstate it. Also, I do not know the modle number. It has a similar shape as the one pictured below, just not as long or compex, and mine is silver opposed to black.
I have got a D770 remote and ive got the codes for the tv but i do not know how to put the codes in the remote so it can control the TV please give me instructions on what buttons i need to push in order to program the remote
I need to reset my remote. The red light is lighting up but the remote is not working.
I have a RCA D770 remote for my Direct T V, it will only turn the box [ direct tv ] on or off. It will not change any channels. I have to use the direct tv botton to turn the box [direct tv] on or off what your suggestion.
i'm tryna figure out how to operate this do you hold tv first and put the codes in how do i know that the codes are being put in
I have a rca universal remote that quit working, I changed batteries, but lost the book with the codes. The red light works when I hit any key, but I need to reprogram it, can you send me the instructions and codes on line?
i need the code lost the information book
need to program remote-where do i start
I have a Universal Guide Plus Gemstar RCA D770 Remote Control and I have to program it but I don't have the book with the codes in it and all the sites I've tried to go don't work or they don't have a thing that helps.. It also doesn't have a code search button which is of no help, if you could help me out I'd really appreciate it. Thanks
I need the code list for my RCA D770 remote. I have a Magnavox tv and need to reprogram the remote
the link for the user manual doesn't work
remote worked but now power button flashes red when hitting any key
