My Ricoh Aficio CL7100 doesn't print any yellow after it has been moved to an other room.
It worked just fine before, and prints as before, except for the yellow. There is anough toner left, but maybe it needs te fill the cardrigde from the toner container (on the top tright of the machine)?
There are no errors on the display or the error log, and all the other color are just fine.
Is there a way to solve this? (whithout replacing any expensive parts)
Can I manualy fill the cardridge, through the printer menu?
Hope you have a solution?
Guido, Rotterdam, the Netherlands
Does the demo page print ok?
try pushing the yellow developer unit in tight.
It sounds like you need a new yellow developer unit. Somehow it might have gotten damaged or jostled when you moved the printer, but that's the most likely reason you're not getting any yellow if there is yellow toner in the cartridge.
I'm not sure how much a new yellow DV unit is, but you might be able to find one for cheap on eBay.
You do not need to replace any parts from the removing of the printer something inside has been displace so i will please you to open your printer and everything like toner cartridges, drums and all other staff that you can get out get them out and putt them again
