Nikon N65 35mm SLR Camera Logo
Posted on May 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Subject is dark when looking through the viewfinder
I have no idea what I have done to my camera. When I look through the viewfinder to take a picture, everything is dark. The pictures that I have developed are dark. Please help me. My daughter's dance recital is coming up and I want some great pictures.
  • Anonymous May 11, 2010
    sounds like your flash is out of sync with the shutter.
Anonymous
Level 2:
Champion:
  • Expert 216 Answers
  • Posted on May 07, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
216
Questions
0
Helped
120071
Points
408
Take the lens off and look at the lens opening on the body - at the 9 o'clock position is the aperture stopdown lever. It should be square to the edge - not bent sideways or too far from the side. It's a pretty flimsy lever and easily bent. You can bend it back square by grabbing with pliers and pushing toward the left side. Common problem.
2answers
When tKing a picture...should my subject appear in the view screen window...the big screen? Or do you have to look in tiny scdeen to see subject when taking a picture?
Use the largest screen to get a better idea of the focus. Smaller screens lack the resolution to show a slightly unfocused shot - but it will be noticeable later when printed or viewed on a large screen. Of course, these screens eat battery life - so you can use your optical viewfinder whenever possible.
Error message is that "subject is too dark" (yes,
Turn up the ISO...or ...turn up the "exposure compensation"......or turn up the lights...or use the flash.
The image looks dark
The finished image looks dark or it looks dark in the viewfinder?
If your question is "the image looks dark" in the viewfinder my answer is it's an F4.5 lens so letting less light into the viewfinder and it will look dark. The big difference will be seen if you are coming from lets say a Nikon 50mm F1.8 which is two stops faster then your F4.5.
If it's the finished picture after you taken it I'd say you underexposed the shot.
2answers
Appears in focus in viewfinder, but isn't
Change your focusing setting to spot focus. Then, focus on your main subject, keep the button half-way pressed while you re-compose the shot and then press it the rest of the way. Does that improve the shot?
Subject too dark in viewfinder
It sounds like the infamous aperture control problem. I had mine fixed by this place:
http://www.garryscamera.com/
They had it for a couple of weeks, and when I got it back it worked perfectly.
Really Dark Viewfinder
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
Pictures look further away than they seemed through the viewfinder
Like all point and shoot cameras, PhotoPC's viewfinder is not 100 percent accurate and will slightly magnify the subject. The actual picture will always appear to have been taken further away than what the user views through the viewfinder.
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
