No, a dehumidifier takes water out of the air where it's placed. If it's very humid in the air, you should have a tank full of water after a few hours.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
If you bought a dehumidifier, you will not need to put water in it. A dehumidifier removes water. A humidifier add moisture to the air, and you need to add water to this. Was your dehumidifier running before and then it stopped? If so, it will have a tank on the bottom that will have water in it that needs to be emptied out. Let me know if this is your problem.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
There can be many reasons why a dehumidifier will
Hi, There are many reasons why a dehumidifier will not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Hi, There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
