Its model# medc200xw1. replaced thermo fuse, high limit thermostat, and cut off switch, and the heating element is good, what else could it be?
Probably the timer. Remove the quick connect from the timer where the big red wire is that comes off the heating element. Check that leg with the leg next to it. moving the timer knob . You should get a meter reading. If you cannot get a read then that timer is fried inside. I did a video which shows one exactly like yours.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: maytag dryer model #mde6657byw wont heat replaced
Check the switch mounted on the motor. Two of the terminals are for the heater element operation. Other causes could be a faulty heat selector switch or timer. These components can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity indicates a faulty switch. These are some items to consider. Hope this helped and best wishes.
SOURCE: Maytag Neptune Dryer Model #MDE4000AYW
It is dangerous to do but you have to turn dryer on while it is apart and wait for limit to open up, then test. !st make sure all connections are ok. The clips and the nuts all need to be tight. If any look dark or burnt that may be your weak link. If you are sure that everything is else is working ok, a set of high limit switches is not very expensive. The voltage is 220 so if your careful you can test at each junction, but be careful..
