Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B Logo
A
Anonymous Posted on Nov 21, 2013
Ice build up on very bottom of my upright freezer
My freezer had a ton of ice in the bottom. when it defrosts it seems to all drain to the bottom and refreezes. There's never anything in the pan underneath the freezer.
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Jan 18, 2008
SOURCE: amana self defrosting upright freezer - drain plug
The subject is a Eureka Model 350 hand held steamer that can be found at Lowes and other places for around $49.95. With this steamer you can thaw out an evaporator as quick as if you were using a heat gun or hair dryer but without the slightest concern about melting plastic or wiring. By using steam instead of pouring water (yes many still do) there is little to clean up. With the many attachments it comes with there are other uses (i.e. cleaning, thawing drains, thawing IDI fill tubes, etc.). The steam also makes the replacement IDI fill tube (rubber end) more pliable and easier to complete the installation when used at the end.
This unit has a trigger and can be used to blow out a stopped up drain on a refrigerator by letting the pressure build up a little then blow through the drain with one of the attachments. As for thawing out evaporators it had a fine jet tip for actually CUTTING through solid ice.
Another great use for this tool is refrigerator door gaskets. The hot steam works faster than a heat gun with out the worry.
Note: Do not aim steam directly onto the plastic freezer liner. The rapid temperature change could damage the liner.
Anonymous
  • 3361 Answers
  • Posted on Apr 07, 2009
SOURCE: frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Jul 13, 2009
SOURCE: Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Anonymous
  • 143 Answers
  • Posted on Oct 12, 2009
SOURCE: Amana 20 - 20 years old. Freezer thawing -
IT SOUNDS LIKE YOU HAVE DEFINITE ISSUE WITH YOUR COMPRESSOR, IT MAY BE CONSTANTLY RUNNING OR RUNNING TOO OFTEN, THIS WOULD CAUSE THE LARGE AMOUNT OF HEAT COMING FORM THE BOTTOM. IF YOUR COMPRESSOR IS RUNNING TOO MUCH YOU WILL ALSO GET AN EXCESS AMOUNT OF WATER EVAPORATING DUE TO CONDENSATION ON THE EVAPORATOR COILS THEREFORE FILLING UP YOUR DRAIN PAN THAT MUCH QUICKER. YOUR FRIDGES COMPRESSOR MAY BE ON THE WAY OUT BUT YOUR FRIDGE SOUNDS LIKE IT'S WORKING THE WAY IT SHOULD BE.HOPE THIS HELPS
THANKS
Testimonial: "You've confirmed my own suspicions. I didn't want to believe it - also confirms why my electric bill has been higher lately. Thanks - I'll toss it."
victorwod
Victor Nwachukwu
  • 157 Answers
  • Posted on Feb 20, 2010
SOURCE: Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
5helpful
2answers
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Upright freezer,automatic defrost.
drain is clogged remove ice with hair drier and hot water
May 09, 2010 • Freezers
2helpful
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
1helpful
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
10helpful
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
2answers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
66helpful
7answers
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Amana Freezer Expert? Answer questions, earn points and help others
