Televison & Video Logo
chris espinoza Posted on Nov 22, 2013
I have a Samsung TV, and am trying to sync my remote with DVD player (Sony) only there is no set button on remote.please help Samsung model #hlp5063wx/xaa
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
  1. Turn on your Sony DVD player.
  2. Locate the code for your Sony DVD player in the code list provided with the universal remote.
  3. Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
  4. Enter the code for your Sony DVD player using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
  1. Turn on your Sony Bravia TV.
  2. Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
  4. Enter the code for your Sony Bravia TV using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
How do I program for playing DVD's on the TV?
If the tv has a built in dvd player, you should simply be able to put a dvd in the drive and the tv will auto-switch to the dvd player.
If you have an external dvd player, ensure it is plugged into the tv.
On the remote you should have a button that says either "Source" or "Video"
Press this button until the video input your dvd player is plugged into is highlighted, then press "OK" or "enter" (some tv remotes have one button that highlights and also selects the input)
You may also press the "Menu" button and check in the "video" section if your tv supports "Auto input switching" This will allow your tv to automatically switch to whichever device (dvd player, game console) is turned on while the tv is on.
Please provide make / model of tv and possibly dvd player for further help.
I need Samsung TV remote control code for setting up Sony Blueray Player remote control.
0279,0277,2870,2851. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Trying to program sony triniton tv remote for my samsung dvd-vcr375 and can't find my manual for code
Hi
Please go to below website and you can fine the codes for your remote
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=32
Please enter your Remote model number and you will get the code
Thanx
6helpful
2answers
Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
1helpful
NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
2helpful
Changed setting with sync recordings and dv1 cannot change sett
Stuck on DVD 1? Please hold the ENTER button. While holding the ENTER button press the number button 1.
Hold down both ENTER button and the number button 1 for more than 5 seconds. Thanks to the Sony Support Team!
I have Sony Universal remote that I cann't sync or learn commands
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Please help
Need akai ninja14 (ct14mn/mk11 ) ctv remot model number
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
