I have problem with my MP150. The thing is that when I'm pushing POWER button, it starts to make routine movements and sounds, at least they seems to be routine as every time when I was starting it. But the display shows E => 2 => 3 in sequence. Ain't have any idea what's going on. I also tried Canon troublestooting but it turns out that I have to contact with servise and it won't tell me what's wrong with it. Please help..
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer: CANNON Printers MP150/MP160 ERROR CODE E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
I am also getting an E5 error although it was working fine before and i have changed nothing.
I have just had my cartridges refilled, they are still coming up as empty. Now there is an error code 1 then 6 flashing. I have tried all the usual, huge backlog of printing to be done. £16 wasted?
I ALSO JUST HAD MY INK REFILLED BUT NOW I AM GETTING A HEAD ALGINMENT PROBLEM. HOW CAN I FIX THIS?
mine says E 3 - how do i solve that????
Basicly the same except, we changed the ink cartridges, and all we get is E5 ....Cannot figure out what E5 means and how to correct..Please advise. Thank You ..Roger
NoMatterWho's PIXMA MP150 => it says E-2-3... Please HELP!! problem, and notify you when a new solution is offered.
e40 is it cant fix anymore?need send to canon?
