Question about Microsoft MS Windows XP Professional SP2
Window Xp Pro Setup Hangs at Logo Screen after reboot
On my New Sata 320GB Hard Disk, Win XP Setup is installed, I also Formatted the hard disk partition when prompted, but after loading and copying the file, when window said Setup is now reboot your PC..
System reboots and hangs at Logo Screen , showing Window XP Logo with a Blue bar which scrolls for three times and hangs in between.
I have tried power off and then again start but it behave similarly..
Now I have tried again the installation and same things happen..
Could you please let me know what can be done..
  • 3 more comments
  • Puneet Jain
    Puneet Jain May 07, 2009
    I have already tried this also, deleted all the partitions and then again making a fresh Partition and formatting it.. It did not help me at all..
    The installation again hangs
    Can you give some more idea..?
    Can I install the window over this Hard disk by a Pre installed Hard Disk and attaching it as Slave.. Does it run properly alone??
  • Puneet Jain
    Puneet Jain May 08, 2009
    I will surely try this step now and will reply back to you.. Thanks for the help.
  • Puneet Jain
    Puneet Jain May 20, 2009
    Hello Sir, thanks for suggestion but this solution fails completely.
    I have copied the files to my Hard Disk. Message prompt up while working in DOS to run the setup..
    Setup file cannot run in command prompt.
    Now tell me, how to solve this problem.
  • Puneet Jain
  • Puneet Jain
    Puneet Jain May 27, 2009
    After spending a month on this project, I had finally resolved the problem by Cloning the HDD. Memory Test was done and shows no error. You guys doing great job in helping others..
    Keep up the good work continue, :)
  • 700 Answers
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
Posted on May 07, 2009
  • fougzki May 07, 2009
    Ok let me give another way. In your hard drive create a partition say about 2gb space, copy all files and folder from your installer disk into the created partition. You can done this as your new hd as external drive from another computer, for easy copying of files. Or in DOS mode but its gonna takes time. Then boot in cdrom using bootable cd going into DOS. Then goto drive path of your copy files say d:\, then browse to it to target the setup files to run setup of windows xp. Then type setup.exe if that is the file to run the installation of xp.
    The reason for this setup is to eliminate issue regarding using regular installer disk reading and cdrom issue. This will make the installation directly read from hd.
    It takes time, but for sure you gonna learn another method.
    Hope I give you another input.
  • fougzki Jun 05, 2009
    Thanks for the input also. And for the patience. I'm glad you make it to work already. And the very professional manner you shows us here.
6ya staff
SOURCE:
I have acer 4741z, its having problem and already formatted hard drive, i tried to install win xp using installation cd, its running ok until the blue screen appear and struck there. How to install win xp,...
It is not a hardware issue. It is easy to install Windows 7 in your laptop but if you want to install Windows XP you have change the Hard Disk type to IDE. For that you have to change settings in your BIOS. After changing to IDE you can continue your installation normally as you done earlier...
thanks & regards
Anas K A
Jun 27, 2011 | Computers & Internet
How can I install internal Toshiba MK3265GSX into my notebook with Windows XP (SP3)? Setup software can't find hard disk. Where can I find driver for this device for XP?
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Feb 27, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Hi, I have formatted the SATA hard drive in my Gateway GT 5408 with Intel motherboard D945GCFG1. I want to load XP pro instead of the original Vista which was on it. Do I need to change the Bios or install...
No, you do not need to install a new driver as long as that is the same sata hard disk tha used to work in your Gateway computer. Just boot into your windows xp installation cd and let the setup continue.
Should you need further assistance, please let me know.
Mar 08, 2010 | Gateway GT5220 PC Desktop
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
Computer system problem
Your hard disk might be SATA interface, and XP don't have access to this type of hardisk. It requires RAD driver for that type of disk.
1). You can make your HDD accessable to XP by disabling the SATA mode in your system BIOS setup. Then XP will access your HDD and it will be installed.
2). You can also make your HDD accessable to XP by atchi driver. Go to your motherboard manufacturer site and download SATA driver according to model number. This may be compressed or auto extract exe. Extract all files and copy it into a floppy disk. Then start your XP and press F6 at first screen, then it will be prompted to insert RAD driver from setup, follow the instructions and XP will be installed on your system.
Thanks
Iqbal
Mar 18, 2008 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Microsoft MS Windows XP Professional SP2 Logo
574 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
