TV worked fine last night, although picture seems less brighter lately. Today, the ON button starts the blue lights (power on), I hear fan noises, and then the blue lights go off. No picture ever appears on the screen. Could it simply be that the lamp needs replacing?
SOURCE: Mitsubishi wd-52525
dear friend you have a power supply problem,so far i fixed about ten of this tv's with the same problem, reply back to me at [email protected]
SOURCE: mitsubishi wd-65831 one night worked fine next day nothin..
i.m having problem were to buy a Mitsubishi lamp cartridge TYPE 915P028010. how much it cost.
SOURCE: mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Testimonial: "no wonder you are an expert, we are nothing without you. huge thanks"
SOURCE: Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
SOURCE: Hello there, I have the
If the lamp light blinks yellow, then the first thing I would check would be the filament of the lamp. It is not completely blown into shrads, but it sounds like the filaments is fried. Please check it and let me know.
Sai.
