Troubleshooting: Image Quality for Cameras
Detailed Description
This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images.
Answer
The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you
are experiencing blurry images, please try adjusting the focus ring
located around the lens. This will allow you to focus the camera image
on objects at different distances. Also, make sure there is good
lighting. Improving the lighting conditions can improve the image
quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet
using video enabled programs such as MSN Messenger, Yahoo! or AOL
Instant Messenger, your connection speed to the Internet directly
affects the image quality of the transmitted video. Corporate LAN,
DSL/cable modem connections will result in the best image quality
experience, while dial-up connections may result in choppy and overall
poor quality because of the slower connection speed. Even broadband
connections such as DSL/cable modem may experience choppy video at
times because of Internet traffic or slow upload speeds. If the image
appears clearly in the camera software, most likely your Internet
connection may be responsible for the poor image quality in your video
program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you
may need to change the settings for your display adapter. For optimal
image quality, please make sure the video display adapter is set to
display at least 16-bit high color or higher. To change the color
palette please perform the following steps:
- Click on "Start," "Settings," and "Control Panel."
- Double-click on the Display icon.
- Click on the tab labeled Settings.
- In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
- Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some
Logitech video cameras have an option for "Low Light Boost." If there
is an option for "Low Light Boost," try enabling the "Low Light Boost"
in the QuickCam software. To do this:
- Open the QuickCam software.
- At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
- Choose "Advanced Camera Settings".
- Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
- If that does not improve the image quality, try adjusting the other
image settings, such as contrast, saturation brightness, gain and white
balance.
- Click OK when your are done.
Thanks for the advise. I saw no change in the resolution. I unchecked the low light enhancement and the video no moves at a normal speed, not in frames. I got a lamp and solved the light issue, but I was hoping that the driver update would give me more of a TV image (crystal clear). It didn't. If you have any suggestions for that, please advise. I don't like Yahoo.
Hi, I have the same problem and my sound is poor as well.
Please help.
Elize Maree
