Will not spin or agitate at all.
The machine will not progress through cycles if the water temperature is not achieved for the cycle and temp you selected. Check the menus for this first. The machine may not be getting the water up to temperature or may not be sensing the temperature. The warranty is three years for these parts. You can call ASKO directly and get help from customer service: 800-898-1879
Posted on Apr 03, 2015
Check motor brushes or capasator
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Posted on Jan 21, 2008
SOURCE: Asko 620 washing machine keeps filling
Sounds like your fill solenoid has stuck in the open position. There are 3 #20 Torx fittings along the back and you can lift off the top panel. The solenoid will be in the back left side.
I would shut off your house water supply to the machine and then do a voltage check to see if the solenoid is remaining energized. Another more simple option is to give the device a few light taps as some debris may have become trapped inside and caused it to become stuck open.
Posted on Jul 27, 2008
SOURCE: asko front loader washer w620
Check your motor brushes. They may need to be replaced.
Posted on Aug 05, 2008
SOURCE: asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Posted on Nov 01, 2009
Jun 05, 2017 | Asko Washing Machines
Nov 01, 2009 | Asko W6021 Front Load Washer
Jul 22, 2017 | Asko W620
Jul 07, 2008 | Asko W620
Jun 18, 2008 | Asko W620
Apr 19, 2008 | Asko W620
Jan 07, 2008 | Asko W620
Dec 11, 2007 | Asko W620
151 people viewed this question
