Sansui TVM1916 19" TV Logo
Posted on May 07, 2009
Procedure for child lock and unlock - Sansui TVM1916 19" TV
thevbat
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jul 14, 2009
thevbat
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
9973
Points
36
Press the power and tv/av buttons on your remote simultaneously  my tv is a  SV-T21PA2S(AFE)
My videocon lcd have 6-digit child lock and i forgot codes , how to unlock it
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
Haywa lc 32w5s code to unlock child lock password.second hand tv found out no sound.child lock was on
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
How to unlock the child lock for panasonic tv tc 20lchow to unlock the child lock for a panasonic tv model tc 20lc
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mt tv is lock child..how to unlock child lock to unlock
2answers
I waqnt reseat child lock off witout remote controal i dont have a orignal remote controal tv digihome model no32723hd
It might be impossible to release the child lock, without its remote control. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Whirlpool 6th sense fridge freezer electronic panel - how do i unlock? child lock not on
Emma:
The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that indicates 3, then 2, then 1, and a soft tone along with the lock icon appears. To reverse this hold the same button for 3 seconds following the same procedure and the unlock icon will appear.
2answers
How will i have this resolved? my sanyo k50 tv showing "locked" whenever turned on??
The TV is locked by someway. If you're using a universal remote control, this might have happen. If you wish to unlock it, you must have its original remote control. For more information go to http://electronicshelponline.blogspot.com/ Unlock procedure to many brand TVs are given. Pull up older posts.
2answers
How to get child lock off of my daughters TV I forgot the code help!
The procedure to unlock the child lock to TVs will differ brand to brand. The general procedure to most TVs are:
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Check this. If you wish to get more details about unlock a TV, check the site linked here. Pull up older posts. Unlock procedure to many popular brand TVs are given in detail.
google.com/+GopakumarGopalan
Lost child lock code and it's asking for it...,.HELP?
If the previous user never used a child lock function, how do this now activated? Anyway, to reset this set, you have to know about the child lock code. There is some details about, how to unlock the child lock, its repair manual will have the procedure. Check this link. It has details about these matters to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
