Hi
You can follow this procedure to wind the bobbin thread--
Step 1--Secure thread on sewing machine as if you were threading machine and pass thread end along indicated thread guides. Thread guides will be somewhat different for bobbin winding than for regular threading.
Step 2--Place empty bobbin on bobbin winding spindle. This spindle will be located on front right, on top right, or on either side of machine. The spindle may have to be repositioned for bobbin winding.
Step 3--Place thread end through one hole in upper portion of bobbin, and pull a few inches of thread through.
Step 4--Disengage the sewing machine needle by either pushing in the center portion of the handwheel or rotating center portion of handwheel towards you. The method will depend on the model of your machine.
Step 5--Take hold of the thread end and pull gently outward so that there is very little slack in the thread. Firmly grasp thread end.
Step 6--Push on presser foot to begin winding bobbin. Hold onto thread end while bobbin is being wound. Wind bobbin only up to guideline marked around the edge of the bobbin.
Step 7--Cut excess thread from the top of bobbin and cut thread that attaches bobbin to rest of thread spool.
Step 8--Insert bobbin into bobbin case, pass thread through indicated slots, and bring thread out a few inches to the right.
Step 9--Close slide plate over thread.
Step 10--Continue threading machine.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
