Had my washer since 2009, take great care of it, never had a problem. Today after 1 load, water started leaking on the floor. Cleaned the drain pump filter, there was no build up. Connections at the back not leaking. What could be the issue?
Check the bellows gasket real carefully for a hole, and make sure the door gasket is good and no problems with how it fits to the front of the machine.
Pull the machine out, and watch it from all angles with any covers off that can be removed without interfering with function. Run a quick rinse and see what leaks.
SOURCE: my washer drain pipe is overflowing on my floor
Sounds like your drain pipe is restricted or clogged. Try using a "Pipe Snake" to unclog.
