We've checked the inside of the washer and there are no snag points. Are there any other possible solutions to this problem (other than putting the shirts in a mesh bag or pillow case)? Could it be the rollers. I have the same problem with tiny holes in all my shirts. All in the same spot too. I am using a slower spin speed and putting the shirts in a mesh bag. I am still having the same problem. I am also air drying the garments. I just don't get it.
I have the same problem. It's not zippers or bra hooks. You have to first check the rubber barrell in the machine. Sometimes little odds and ends get into there from pockets. Second, you have to pull open the tiny door on the front bottom and drain the stupid thing on a regular basis. Be prepared- a LOT of water comes out. And even if you use a bowl, the machine is designed well to hold the water that comes out. After that, you have pull the hose next to the drain out and unplug it. Even more water will come out. I usually find some nasty thing in there that is the culprit. I hate this machine. It has destroyed just about everything I own.
It it the button on your pants or jeans!!!!!!! Test it out
Hi
The smell usually comes
when the washer is unable to drain water completely, you can run your washer at
its hottest temperature setting with 1 cup of vinegar inside the unit. After
this take off the bottom front panel and clean it completely, also clean the
drain hose and drain pump filter, the smell should disappear after doing all
this. Hope this helps...please post back for further assistance.
Daniel
