SOURCE: Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
SOURCE: My cordless HDR 130 Sennheiser headphones no
The batteries are at end-of-life OR your charger has failed.
Forst replace the batteries... they are MOST likely bad. Charge the new ones before using.
SOURCE: my sennheiser hdr 130 has no sound even though it
This worked for me (this solution was posted on another thread). Unplug the base and take out the headset batteries. Wait 30 seconds. Reconnect. Turn on head set. I could hear immediately!
SOURCE: my left channel in sennheiser
As long as it is NOT a wireless or noise cancel type, try looking at my tip on headphones dodgy cable/plug problems.
SOURCE: No sound in left hand
Try to unplug the plug (jack) or loosen it or move slightly within the jack holder, if you get the sound back and looses if you move your hand then its the jack is causing the problem.
If any of the above said is not making any difference in the headphones left ear then the left speaker is bad defective.
If you can get the speaker with same watts and ohms etc then you can replace the left ear speaker with it with the help of a technician or better get a new headset.
Hope this helps!
