The cubic feet capacity of your KSRS25QFWH00 refrigerator depends on its specific model and configuration. However, according to the product specifications for the KSRS25QFWH00, this model has a total storage capacity of 25.1 cubic feet, which includes 15.4 cubic feet of fresh food storage and 9.7 cubic feet of freezer storage.
Katy,
It is going to be in the neighborhood of 18 cubic feet. Most manufacturers will put the cubic foot size in the model number but it can be a little smaller and it could go a little higher like 18.2 or 18.3 cubic feet and they would still call it an 18. Hope this helps!
Here is a link to the owner's manual:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-10659592990/0582/0165000?modelNumber=10659592990&diagramPageId=&documentId=
Normally the first two numbers in the model number are the cubic feet. You have posted 2 model numbers, on appears to be 21 cubic feet and the other is 17 cubic feet.
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height With the dimensions you give Volume=12.5in X 37in X 20in Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot. L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728. your answer is 5.35 cubic feet.
12 inches in 1 foot 144 square inches in 1 square foot 1728 cubic inches in 1 cubic foot
to convert you put the unit you want to keep on top of the dividend. to conver to to feet ( randomly selecting 100 inches) Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet 12inches
or cubic inches to cubic feet 4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft) 1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit. it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in) 1cu ft
