Somehow i have turned the silent mode off on my phone, and i have tried everthing to activate the silent mode back on and it doesn't work. can anybody please help me.
Hi i cant activate my phone to go to the silent mode. i might of set something wrong to make the silent mode not to work but i cant fix it to turn the silent function back on. can you please help me.
Re: somehow i have turned the silent mode off on my...
Or by holding down the # key :) you may have changed the profile itself, so check under profiles > Silent check the settings in there are actually set to silent...
Go into settings on menu, go to ringers and volume control and make sure that the settings are all on. If that does not work than I would try calling your service provider. Good luck!
Hi!
Some phones have a double function for the "#" button.
Press and hold this button "#" and the silent mode will turn off/on.
I hope this will work!
Have a nice day!
*please don't forget to rate my support :)
hi, have you tried enter setup then profile then select general this should then set your phone back to normal if not then instead of going to general go to silent and change the settings under the silent profile, like turn ringtone on and select ringtone. Try the first option first as this is quick and easy failing than then just change the settings under the silent profile then you can even change the name from silent to general then you can change one of the other profiles to silent so try it then get back to me if you need further assistance ok
To Enter/Exit Silent Mode
Silence the tones your keypad makes when you press a key.
• In standby mode, press and hold # key. Entering Silent Mode briefly appears in the display and your phone returns to standby mode.
u can activiate silent mode from phone profiles
