I replace both rear air springs on my envoy denali and it it still wornt inflate all the way up and u could hear the compressor working what can I do to fix the problem
Two possible causes, 1. First gear has been stripped and will need replacing, or two the selector is not engaging the gear. Get yourself a manual, I can't help you but you can have a look any way:
After assessing the situation you have to make a decision as to your approach. With a manual, sometimes it is good just to inspect the problem area, but i feel you might need professional help.
if your cd wont read disk then maybe it got damage. you can change the drive let it repair.
Other method installing windows is to seek USB port DVD drive and then connect it boot the system using this external DVD drive.
method 2: You have to remove you have drive and attached to other pc using drive enclosure and then copy the installation disk to the drive. then boot you system if still boot and if not not then you have to boot using DOS base system. You can search documentation installaling XP using DOS command. you can search it in google.com.
