My PST file is damage,When i am tring to restore the pst file in outlook a error is coming this is not valid personal folder
There might be various reasons by which the PST file gets damaged or corrupted. It shows an error while you access the important data. You need to repair the damaged PST file instantly. You can use the PST recovery tool to recover the corrupt or inaccessible data without any hassle.
For more info, read - https://www.data-recovery-solutions.com/pst-recovery.php
Damage PST Can easily be solved but how many times do you want to recover your PST File. Don't you want to prevent your PST files from such corruption so there will be no need for recovery?
ScanPST is a good enough tool to recover PST files that the chances are rare that PST file hit by severe corruption and only, in this case, you need a PST Repair Tool. But if you know some prevention tips then you can outstand from such corruption in PST file.
Here's a Complete Guide to Outlook PST File.
If you want to access data from damaged and Inaccessible PST file then you need a trusted Outlook PST Recovery Software. The software should have all required feature to repair and recover emails, attachments from new PST files. The Outlook PST Recovery Software is quite easy to operate due to user friendly interface. I recommend you to first try its free demo version and analyse all features and working of this software.
Get more details, Visit here:- https://www.downloadtopten.com/recovery/pst/
Kernel Outlook PST Recovery recover all the lost/deleted/corrupted data files of Outlook. It provides you unique facility to recover all the damaged data along all personal folders & attachments. It's demo version gives you facility to view preview of all recovered data and software frequently save all the recovered data into PST, EML, MSG file format.
You can use Kernel for Outlook PST Repair Tool to repair your damaged Outlook pst file successfully. Go to http://www.pstfix.com
to download the tool and refer to http://www.pst.msoutlookrepair.com
to know more about the pst recovery.
I would like to suggest you to use RecoveryFix for Outlook PST repair software which intensively scans the damaged PST file and extracts the mailbox data. Visit http://www.en.outlookrecovery.net/repair-pst to know more about the tool and download free trial version.
Unable to restore PST file in Outlook? and getting error while accessing PST file, to fix this error and repair PST file you can use PST Repair Tool
Nothing to worry if you PST file get corrupted or damage, you can repair them easily using Outlook Inbox Repair tool. if having problem during fixing corruption or tool unable to repair, you are advised to use third party tool. Get more information about it-
http://www.inboxpstrepair.com/how-to-select-best-inbox-pst-repair-software-tool-available-online
Repair all your Pst Files with the help of Outlook Pst Repair Tool Click the following link:
http://pressreleaseping.com/new-and-advanced-outlook-pst-repair-now-compatible-fix-oxtender-2-application-error
There are many of the reasons that are responsible to damage the Outlook data. And damage will make all the data and files in-accessible so there is an immediate need perform the recovery for the damaged files that can be done with the help of the inbuilt application, scanpst.exe. But in several severe cases of damage data could not be recovered. In that case user can use the advanced PST Repair Tool to repair the damaged data. You can get more information about the software from :http://www.pstrepair-tools.com
In case corruption .pst file you need to utility working under all versions of MS Outlook. I should advise you to look at helpful software below outlook fix utility helps you to restore corrupted .pst file in couple steps of recovery wizard.
You can take help of scanpst.exe tool which is an inbuilt utility provided with Microsoft. Using this tool, you can easily repair corrupted pst file. However, if the size of the file is above 2GB then you must consider third party pst repair tool. In my opinion Stellar pst reparieren tool is best. It uses powerful technique to scan entire Outlook to repair pst file and then restore all mail items.
please follow this link
http://office.microsoft.com/en-us/outlook/HA010563001033.aspx
you can repair pst. it is very easy task.
just find SCANPST.EXE file in the computer
then dubble click on the scanpst.exe and give the path of pst file which you want repair
or
On the
Start menu, click Run.
drive:\Program Files\Common
Files\System\Mapi\LocaleID\scanpst.exe
where LocaleID is the locale identifier (LCID) for your
installation of Microsoft Office. For example, the LCID for English
(United States) is 1033. For a list of LCIDs, see Microsoft Office
Help.
Note You may not be able to use the Browse
button to locate this file because it is located in a hidden folder.
Thanks
veeru_india
To restore a file .pst, follow these steps:
From the Start menu, click Run.
In the Open box, type:
Code: Select all
drive: \ Program Files \ Common Files \ System \ Mapi \ KodYazyka \ scanpst.exe
Click OK.
In the Enter the name of the file, enter the path and file name listed in the error message above.
Note. May not be able to use the Browse button to locate the file, t. To. It is located in a hidden folder.
To change the logging during the scan, click Options. If the switch is set to replace or supplement protocol protocol, the log file will be saved in the same folder as the file .pst.
Click the Start button.
When the scan is finished a file, select Create a backup copy of the file before restoring.
Click the Restore button.
If the file has been successfully restored, a message is displayed that the recovery is complete. If using a recovery program "Inbox" file is not recovered, you will need to use a backup file.
Or try to recover files through the program Outlook Repair Kit. She saved me many times.
[url=http://www.microsoftoutlook.repair/]http://www.microsoftoutlook.repair/[/url]
Still I recommend to visit this forum
[url=http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook/604-how-to-recover-pst-file-is-too-large]http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook/604-how-to-recover-pst-file-is-too-large[/url]
