Laptop* It sits in your lap. If you open the laptop you will discover dozens and dozens of electrolytic capacitors. All electronic equipment have them. They are the most common cause of failure. They have an electrolyte in them just like a battery does. Over time this electrolyte dries up. Every 4 or 8 years it is good to replace them. Bad capacitors will be bulging. The tops have a cross on them to allow them to bulge if it needs to so that they don't make a pop like fireworks..
SOURCE: can i change my acer aspire 5720z keyboard
Yes you can and here is how
www.youtube.com/watch?v=FoTwln2SyQ4
SOURCE: Aspire one AOA-150 acer labtop with 3310 bio still no charge
If the unit is running fine with A/C power then your A/C power is fine.
If the unit cannot run when both the battery and the A/C are connected then the battery needs to be replaced.
I had two units 2 months ago with this issue. They dont go on at all when their battery is connected along with the A/C - as the battery is faulty. When I replaced the battery everything was well again.
SOURCE: ihave acer aspire 5332 labtop
You don't have bluetooth in that laptop. You must buy a separate USB dongle and install it. Here's one
http://www.amazon.com/Bluetooth-USB-Micro-Adapter-Dongle/dp/B001EBE1LI
