SOURCE: PF indication (Power Failure) and dryer digital light up but will not start
check your owners manual for clearing error codes in trouble shooting on theese electronic models lots of time you have to clear the codes to go back to normal ops by pushing certian buttons on kenmore i dont know which ones they are usaly its clear/cancel buttion some times you have to holld them so many seconds just unplugging it will make it think it has another power failure
SOURCE: check lint screen light is on. the dryer doesn't
ck continuity at switch ck at the motor.
motor sounds like it went out.
ck for juice at the motor and relay for the motor.
SOURCE: my dryer check lint screen light continues to
Airflow through the dryer vent is restricted. Blow through the filter opening with a reversed vaccum cleaned. Set it BLOW instead of **** usually by putting the hose on the exhaust end.
SOURCE: i have a kenmore elite dryer that will not start -
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
