All images projected by NEC VT540/440 projector have a definite pink cast. Adjusting the color temperature in the Advanced Settings helps a little bit but does not correct the problem.
Sounds like one of those problems only cureable with expert knowledge of for example Chroma feed , Lcd function , lamp luminence, not to be a killjoy but it sounds like this is one for the engineers an estimate should be free and even if you dont have it fixed you'll know whats wrong if you want to do it yourself providing you have adequate training of course .... Regards vortash
Thanks, Vortash. I suspected this problem might require an expert's touch.
Just interested if this was solved as I have an old projector with the same problem. Is it worth fixing, or even able to be fixed?
