Mitsubishi WD-57734 57" HDTV Logo
T
Terri Markloff Posted on Nov 27, 2013
Whining noise For a couple of weeks my tv would make a whining noise when I turn it on,now it is beginning to make the whining sound while the tv is on and there are small white dots and what looks like small bits of dust on the screen. I purchased the tv in 2008
zorbrack
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Nov 28, 2013
zorbrack
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
4031
Points
50
Your color wheel is going out. order a new one and come back to me I will walk you through the process of replacing it
5 Related Answers
A
Anonymous
  • Posted on May 29, 2008
SOURCE: Little white dots on the screen
Had an authorized warranty repair center out, they said the projection bulb needs to be replaced, "good thing it's under warranty." They should be back next week to replace, hope that fixes it.
Anonymous
  • 5138 Answers
  • Posted on Nov 02, 2010
SOURCE: My 65" DLP T.V. has started having small white
Optical-Eng PN# 938PO75020 Encompass Parts Distribution has 5 left in Stock
Price $1,415.51- core fee $300.00 Final Price $1,115.51 1-800-638-3328
PTS rebulit Optical Eng. 1-800-844-7871 Call and ask what they charge.
John Riley
  • 441 Answers
  • Posted on Nov 13, 2010
SOURCE: Small white dots are showing up on the screen when
The white spots you are seeing are a result of dust or dirt in the light asm. Mits knows about this as a problem. The inside chamber of the tv needs to be cleaned. If your tv is in warranty they will come to your home and fix it. If not it is very easy to damage the tv by trying yourself, start with cleaning out the chamber that the bulb is in, use compressed air to blow out dust and dirt, them on the sides of the tv are round flaps that will need to be removed and this will go into the main mirror chamber, be careful but blow out any dust or dirt you see on the mirror. I would have a repair tech handel this unless you are skilled in this area.
good luck
Anonymous
  • 167 Answers
  • Posted on Dec 19, 2010
SOURCE: I have a 65 Inch
the DLP chip is going bad you need to replace it to correct this issue
Chi Chu
  • 8457 Answers
  • Posted on Sep 04, 2011
SOURCE: just paid to replace the
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Whining sound in my mobility scooter
hi, in most cases it nothing to worry about , the shaft that runs from the motor to the axle bearing , the bearing where the noise is loudest.
Brand new Scooters can develop this whining sound after only a couple of weeks. Normally louder when under load otherworld's going up hill etc.
Regards
Rob
Samsung DLP fan noise, TV won't power up
Sorry, not a solution. I am here with same question. It has happened just as you said 4 times in the last two years.
Engine making whining noise
There are a couple of things to check. If your power steering pump is low on fluid, or a bad bearing is in the Alternator, they will whine. The PCV valve or any hole in the Vacuum lines will whine as RPM is increased. Even having the Air filter box not fully seated will make a whining noise.
Now both automatic and manual transmissions can whine as RPM is increased. Check fluid for each.
Serpetine belt and pulleys-can make noise.
Sometimes you can shift into neutral at any speed and the engine rpm will drop almost instantly as the car rolls at speed. If the problem disappears as soon as the rpm drops, then an engine part probably is the reason.
Whining noise whendriving
Could be a front hub bearing or axle shaft.
I have a Hitachi Ultra Vison 57S700 2004 model, the TV has had a slight high piched whine for a couple of weeks and today the screen went green then black and the sound was gone. When it is turned on the...
This tv is under five years old?Yes,it is worth fixing.Over five,i would compare the prices for a new LCD tv and the quote priced from the Tv Tech.for the old tv.This tv have high voltage problems around the Deflection circuitries area.Could be any things burn in this area.The high pitched whine sound,i'm sure it is from the FBT-the high voltages flyback transformer,high voltages current have no where to go.Must hire a tv tech. to troubleshoots and replace parts on the Deflection circuitries area.Also the FBT could be dead too,because HV Current bounces back forth and have no where else to go.The prices to troubleshoot unknown problems is about $400 bucks and plus cost of replacement of parts.
1helpful
Front end noise when turning. almost sounds like
There are a couple of things to cause metallic sounds when turning. First thing, is if it's a clicking sound when you turn, then you have a cv joint going bad. It's usually more prominent when moving in reverse, however it can happen just as well while moving forewards. Secondly, if it's more of a grinding or scraping noise, we have a couple of options. The sound could be coming from the brakes, if they're worn or have grit stuck in them, or it could be bad bearings in the front wheel hub. The wheel hub has a tendency to making a whining noise when driving; usually most easily heard when driving past buildings. They can also allow the tire/wheel to present the appearance of leaning when looking at it. If bad enough, it can even rub on the brake caliper, or cause the disc brake rotor to wear out the brake pads prematurely. So, to recap: Check:
CV joints, if a clicking sound brakes or wheel hub bearings if grinding or whining sound.
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Dryer wont start
Your motor is bad.
Apr 19, 2009 • Dryers
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
2answers
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
