Dryer is making a loud screeching noise off and on, what to take front off so I can inspect it need step by step please
SOURCE: Washer: Thundering herd of elephants. Dryer: Increased drying time
if vent is clean, did you push it too far back afterward and flatten vent hose? also blower fan may be loose on motor shaft resulting in slower rpm also may be excess lint in blower housing ..washer suspect lower bearing although not sure what a stampeding herd of elephants would sound like ..if noise is on spin if during agitation suspect transmission gears ..both will require new transmission ..if noise is more of a knocking noise possible broken bolt in basket trunion block remove agitator to ck
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
SOURCE: It appears that my front loader drum is loose and
Your shock absorbers are problably broken and need to be replaced. Take off the bottom inspection panel by removing the 2 screws on the bottom of the panel and pull the piece down and out. Then take a look inside the machine in the bottom middle on both sides. There should be a shock absorber on each side and these are plastic. Check to see if they are broken at either end and if they are, go to your local appliance repair shop and buy/order a new pair. The new ones are slightly upgraded by making the body out of metal and the rest out of plastic. Instalation instructions come in the package as well as a pair of new absorbers. Hope this helps.
SOURCE: dryer makes screeching noise..dries the clothes
at the top of the drum there is a felt pad with 3 white nylon glides attached to it. if this is worn, and it does wear, it will make a screeching noise like you described because it changes the postion of the drum and it will also appear like it is loose. you can purchase this part as a kit along with the glue to hold it on and it is not an expensive part. hope this helps.
SOURCE: I have a Fridgedaire
The symptoms that you describe sounds like the spider arms that support the drum are broken. It is a very expensive repair. Get a few estimates, before deciding whether it is worth repairing or replacing. Sorry.
