The whole system might have been reset to its factory settings, after you hit the reset button. Do a re-tune, and do all other adjustments similar to previous screen, before you hit the reset button. There is no other fault. Refer its user manual for details.
Testimonial: "When I hit the reset button, I still get nothing. I can't do a re-tune if I have no picture ?"
SOURCE: My Sanyo Tv (model dp327460 is Busted
You should try and download the users manual if you do not have one...I remeber seeing in it that after hooking every thing up, you have to do the channel search twice before the unit will work properly..This is highlited in the manual with correct hookup diagrahm..
SOURCE: power light comes on, but no sound or picture
I had the same problem and my tv was out of warranty. I took it to a local repair shop and they told me didn't work on that brand. They said they charge $300 minimum for labor, plus parts. So probably at least $500 to fix. Since I figured we had nothing to lose my buddy and I took it to our shop at work and decided to take it apart and look for any obvious problems such as blown fuses, burned components, etc. All of the printed circuit boards are connected to what appears to be similar to a motherboard via data ribbons. We disconnected the data ribbon of each PCB to the microprocessor PCB and turned on the TV. Each time it turned back off after about 3 seconds. When we disconnected the Y-Main PCB the TV stayed on and I got the sound back, but no picture. We then disconnected the buffer PCB's from the Y-Main to ensure they were not the problem. Finally, we pulled the fuse on the Y-Main PCB and reconnected the data ribbon and the TV and sound stayed on again. I found a site that sells the Y-Main for $179 and I am deciding whether to try it or not. Any suggestions or comments would be helpful.
SOURCE: Lost the remote & Sanyo Vizon is stuck on a "D" screen
If you use a tv dish or cable box you could program the cable or dish remote to control your tv. Look up the codes online
