Question about Premiere Microscopes MRJ-03 Microscope
I need ti find a spare electric board for a PREMIERE MRJ-03.
THERE NO POWER BEYON THE FUSE SO IT CAN BE ILLUMINATED. BY THE WAY THE LAMP AND THE FUSE ARE OK.
  • 45 Answers
Check the cable connections, a cable might be loose or just disconnected.
Posted on Jul 31, 2009
6ya staff
SOURCE:
2002 ford expedition interior lights are not on what fuse is it?
Courtesy Lamps - central junction box. fuse # F1.21 that goes to interior lamp relay in the instrument cluster and F.24 this fuse powers battery saver relay .
Interior Lighting The interior light system consists of the following:
  • front map lamp assembly
  • front door courtesy lamp
  • generic electronic module (GEM)
  • glove box lamp assembly
  • central security module
  • interior lamp switch
  • interior lamp relay
  • illuminated vanity mirrors (Navigator only)
  • reading lamp assembly
  • rear courtesy lamp
  • running board lamp
  • underhood lamp assembly
  • The generic electronic module (GEM) illuminates the interior lamps when an unlock signal is received from the remote anti-theft personality central security module. The illuminated entry feature will be canceled when any of the following conditions are met:
    • 25 seconds have elapsed since the illuminated entry feature was activated and the interior lamp control is not activated (door ajar or courtesy lamp switch on).
    • The GEM receives a request from the central security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
    • The ignition is in the RUN or START position and the interior lamp control is not activated.
    The GEM will illuminate the interior lamps when any door is open or ajar. The interior lamps are; the dome lamp, the rear cargo lamp, the door courtesy lamp and the side rail lamps. The courtesy lamps will shut off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps will not be reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp switch is received.
    The GEM controls the interior lamps illuminated entry function by activating the interior lamp relay.
  • You have an electronic control module and relays involved in the operation of these lights also !
  • What
    Jan 08, 2015 | 2002 Ford Expedition
    Where the fuse box to a 88 ford thunder bird 5.0 liter
    The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
    If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
    1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
    Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
    May 20, 2011 | 1988 Ford Thunderbird
    I recently replaced the lamp - part # 915P061010. But the TV powers off about every 20 - 30 minutes / red status lamp is illuminated. At times the TV will remain on for hours. But eventually the TV...
    It looks like your ballast board is going bad, this is a common problem for DLP TV's the ballast board is the power source to the lamp and if for any reason this board does not send enough energy to the lamp it will turn off, It looks like your ballast it starting to get weak it gathers enough energy to turn on but gets weak again and turn back off you have a new lamp and it requires for the ballast to be working at it's full potential
    Sep 13, 2010 | Mitsubishi WD-57734 57" HDTV
    My premiere microscope MS-01 Ultra will not focus
    There is what is called a "stage stop" screw. Its purpose is to limit the specimen from rising high enough to contact the objective lens. The "stage stop" screw is directly behind the black stage platform in plain sight and very easy to access. It is a thumb screw and sits vertically. Simply loosen it a bit to allow the specimen to rise high enough to focus.
    Jul 25, 2010 | Premiere Microscopes MRJ-03 Microscope
    I have a tdr125 (03) and it wont start the starting motor turns over but it jus wont catch can anyone help
    If the engine won't fire so to speak, it is either fuel starvation or an electrical problem stopping the spark plug from igniting the fuel.
    If investigating these is beyon your knowledge base, you will need to take your bike to a motor bike repair shop.
    Graham (TDR Fan)
    Jul 12, 2009 | 2000 Yamaha TDR 125
    I own a MRJ-03 Premiere microscope with the a bad electric board. How can I get spare parts for it? abnernm@hotmail.com
    I have the same problem and can't find parts anywhere. Premiere Microscopes doesn't answer their phone or return calls and their customer service email keeps rejecting everything I send. Please let me know too if there are parts available for this microscope.
    Robbie.Dietrich@gmail.com
    May 08, 2009 | Premiere Microscopes MRJ-03 Microscope
    Eyepiece and objectives - they seem to be loose.
    sir,
    There is two kind of eye-piece in microscope one is (push in ) and second one is tread mounted.
    As per my i know you have push in eye piece.
    See in side that cylinder where you are pusing in this eye piece there is two jows is there it resist to come in as well as when you take it out.that pressure of jows you should be increase.
    your problems will short out.
    INDRAVIJAY
    Jan 10, 2008 | Premiere Microscopes MRJ-01L Microscope
    Toshiba TDP-S20 lamp problem
    The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
    Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
    Premiere Microscopes MRJ-03 Microscope Logo
    107 people viewed this question
    Top Premiere Microscopes Science & Laboratory Experts
    Pokinhas
    Tom Chichester
    Are you a Premiere Microscopes Science and Laboratory Expert? Answer questions, earn points and help others
