Question about LG Flatron 563LE 15.1" LCD Monitor
Monitor light blinking
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be
  • maddox21 Mar 07, 2009
    same problem, monitor blinks and goes off. no image
    Problem Solver:
  • 17 Answers
Some monitors blink 2 different collers and that means that their is no video signal and some monitors will blink real fast.This is caused by a power cap going bad.If this is happening you need to take appart the monitor and look for a power cap that has stuff leaking out of it or one that has a loose connection to the board or one that is bubeling on the top the power cap.The top of the power cap should be extremly flat.(here is the problem their could be a bad power cap and it might not be showing any signs of going bad).You will need to replace the cap.You can go to radio shack or fry's and they will usually have the parts for cheep.You will need to know the voltage and the pecofarrets.The voltage and the pecofarrets are usually listed on the cap.For example 350 voltage and Fu 4.5 (Fu standing for pecofarrets).You will need to remove the old power caps by applying heat with a soder gun to the under side of the board.Make sure you know which prong on the power cap is positive and which is negitive as the cap is polarity concious.(usually on the doard under the cap it will say + or -.The longest prong on the new cap will be positive).Once you have identified the bad cap or just replaced and removed them all you will need to use a soder gun and soder to atach the new power caps to the board.After sodering cut any acess langth of the prongs off and reasemble the monitor.Now hopfully the monitor works.
Posted on Jul 28, 2009
Power supply is stuffed maybe
Posted on Oct 05, 2008
6ya staff
SOURCE:
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
LG Flatron 563LE 15.1" LCD Monitor Logo
250 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
