Anonymous Posted on May 09, 2009
Lexmark 2470 only prints 1 page out of 10 pages!!!!
I have a Lexmark 2470 printer and I have installed everything correctly using the Windows Vista driver(downloaded from Lexmark website). Seems to be working, e.g. print test page. The only problem now is that the printer only prints 1 page when its suppose to print more than 1 page. For e.g. the printer only prints the 1st page of my 10 page Word document and it says its completed. I checked out the printing process, and what i saw is that the printing process for 2nd page deletes itself and abort operation. Tried uninstalling and reinstalling back but it wont work. Help!!
Roopesh S
Level 2:
  • Expert 228 Answers
  • Posted on May 09, 2009
Roopesh S
Expert
Level 2:
Answers
228
Questions
0
Helped
70428
Points
559
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 2400 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
Testimonial: "Thanks!"
Kyocera FS-1020D starts print 1/2 way down page
Internal tests like Report Prints are printed correctly? Make sure the Paper Size Format is setted correctly both on PC and Printer. Try not to use a Generic or Universal Printer Driver. Try installing printer with an Windows Vista driver if the Win7 and 8 drivers won't solve the problem.
5helpful
2answers
How can i install my lexmark printer Z735 to windows 7 laptop without c.d.
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_Z735_COLOR_JETPRINTER&segment=SUPPORT&userlocale=EN_UK&frompage=null#1
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
2answers
Cant install lexmark x2600 on windows vista
You need to install the Vista version. Goto this site-download the driver-install-enjoy!! http://search.lexmark.com/printer/US/en/12L1685.html
Lexmark x3650 not printing after installation with my vista lapto
You can lastly try a hard reset of the printer but if that is to no avail the printer has an issue with it. See if you can get it to work with another computer for the heck of it just to make sure.
3helpful
2answers
Lexmark 1290 on Vista Printing Blank Pages
Fond this on the Lexmark Website. Hope it helps.
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· 1) Disconnect your USB cable from your printer.
· 2) Uninstall all Lexmark printer drivers on your PC.
· 3) Download the correct Vista driver for your model.
· 4) While leaving the USB unconnected, Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
I just bought a new DELL computer with the windows vista program. I alredy instaled the software for my Lexmar X1240 printer with the 1200 series disck. I can not print because each time I try to a window...
This is from the Lexmark Support page:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model. (From Lexmark Support)
· Install the driver on your PC.
Here's the support page:
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
If you need more help, just ask.
2answers
Prints only one page
what does the page que show?
so if you print 10 pages, it prints 1 but does the que show anything or does it show 9?
k24674
ADMIN Andrew
ADMIN Andrew
