Dishwasher works normal then perodically on long and medium wash at end of cycle there is water remaining in washer and the drying cycle has completed but glasses and dishes covered with white film as the drying cyce has been trying to boil off water ,, macine if you open door is very hot and full of steam Darryl
Check that the drain pipe is not blocked or has a bend in it as this will stop water passing easily, remove and blow down pipe to make sure its clear. (wash out mouth afterwards) if this is fine then the pump must be weak or something is stopping its movement. if it is the pump you will need to remove it from washer and open the pump up by the 3 screws and remove the propeller and clean out the housing and pump parts, should be magnetic type and easy to fix. build up of food debris can limit the pump from moving.
SOURCE: When the dishwasher cycle is complete there is a thick, cloudy film
jcb...It may be that your detergent is not the right one for the job, you're using an amount that is too much or too little or your water isn't hot enough. Water should be at least 125 degrees. If you don't have an turkey/candy thermometer, run the hot water and put your hand under it...carefully. If you can hold it there...not hot enough.
You might also see if there are filter screens in your unit. Clean them.
SOURCE: Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
SOURCE: glassware is cloudy
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
SOURCE: cloudy dishes
new product designed for this problem. Free samples available!
CloudyDishes.com
The problem is hard water leaving those spots. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
