Www.nflcheapwholesale.com the jerseys are very cheap.
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor
P1108 Right MAP Sensor Circuit
P1112 IATS Circuit High Voltage
Sorry but none of your codes match up with either the generic code or jaguar codes
sp iam now looking at the ford codes who were the parent company at the time of manufacturer
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1722 Gear 2 Incorrect Ratio
which seems to work as i have two answers here but i would check with the code reader web site ,have you checked the oil level ,start engine handbrake on and brick behind the drive wheels .select reverse and then check oil level ,standard dextronII is all you need to top up
