Triumph Academy Sports 400T Treadmill Logo
A
Anonymous Posted on Nov 29, 2013
Error Code E1. Then it shuts off. - Triumph Academy Sports 400T Treadmill
E1 error code on a cz220 comfort zone model heater what does it mean
The E1 error code on a Comfort Zone CZ220 heater indicates a problem with the high-temperature limit switch. This switch is a safety feature that shuts off the heater if it overheats.
To clear the error code, you can try resetting the heater by unplugging it from the power outlet and waiting for at least 30 seconds before plugging it back in. If the error code persists, it may indicate a more serious issue with the heater that requires professional repair.
2answers
Error E1 for washing machine
AK Techno service is the best service center for repairing and service for all types and brands of washing machines.
For more visit our website. http://aktechnoservice.com/samsung-washing-machine-service-center-in-hyderabad
samsung washing machine service center in hyderabad...-bo0djorvxqfflml1tozu5o0f-5-0.jpg
What wrong my comfortstar mini **** outside unit not coming on and I am getting e1 error code
I am somehow listed as someone who "solved" a Comfortstar mini problem - but I have not. And the company that installed it cannot. I am really fed up with the stupid thing.
1helpful
1helpful
F1 e1 error code...oven has previously cut off
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
6helpful
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
4helpful
5answers
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 • Dryers
10helpful
3answers
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
2answers
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Top Triumph Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Triumph Exercise and Fitnes Expert? Answer questions, earn points and help others
