If the TV is already hdtv...no. Try reprogramming tv to find hd stations or if receiving signal from outdoor aerial make sure aerial is digital and facing right direction.
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
First Converter boxes are a poor economic investment. Second you have an HDTV. It does not need a Converter box. Just connect an amplified antenna.
Specs:
Built-in ATSC QAM Tuners - QAM and ATSC tuners included to enable the set to receive Digital cable-in-the-clear signals, as well as digital terrestrial broadcasts. HDTV reception is possible by adding an Optional HDTV antenna
If you are picking up only analog channels, you will need a converter box. You can pick a converter box up for $49 or $59 dollars at walmart or target. Best Buy is way overcharging if they are selling them at $100.
You Dont need one your set is HD. So when the switch happens you are good to go. The only TVs that are going to need converter boxes is those who do not have HD or only have antenna.
no need to convert ,,i have same tv,,hdready just means it has no built in converter. You just need a HD converter box or a cable box or dvr that is also an HD receiver.
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
Hi Drtrippy, If I understand correctly, you are using your VCR for the actual tuning of the TV.
The converter box itself contains a tuner, so you should now receive extra channels available only to an HD tuner.You should try connecting your antenna as input to the converter box.Then output the signal from your converter box to the VCR.Your VCR may then remain connected to your projector.
You may simply think of this as if you are inserting the converter box between your antenna and your VCR, which should be currently connected to receive an over-the-air signal.Remember, as the tuner you will be using is in the converter box, you will need to change channels using the converter box, not the VCR.
