SOURCE: no charge
If it's not charging most likely it hasa bad battery to see go to the store where you boughtthe dewalt and have them try putting it on a charger and see if it will take a charge, also the tongs inside the charger could be bent and causing it not to make contact and will need to be bent out a little to get it to work.
SOURCE: what do i need to know about charging the batterys
Yes, three times. Run them all the way down.Then fully recharge
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Testimonial: "cheers mate"
SOURCE: Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
SOURCE: Need to know what terminals
I do not recommend connecting anything but the factor charger to the battery. No 12v will not not charge an 18v battery.
They can BLOW UP if you apply too much current.
The correct charger can be found cheap. Look on craigs list under tools.
Good Luck
SOURCE: 12v drill/driver not holding charge
Seems like your batteries need to be repaired and recharge! For this, let me suggest you the ultimate Nicad battery repair guide. This is very efficient and works on all weak or dead nicad batteries. With this nicad battery fix manual, you can repair, recharge and make your old batteries work like new ones. it is easy to understand and easy to work on. Recharges the batteries within no time. Try it, it is really helpful!
