Splendide Comb-O-matic 6200 Non-Vented Washer/Dryer Logo
R
Roxyslow Posted on Nov 30, 2013
How to replace belt on 6200 i cant stretch belt to put on
I cannot stretch belt to replace it is there a trick
Oreck XL Vacuum. Is there a special tool needed to stretch a new belt over the roller and drive shaft?
There are a couple of tricks. One is to put the belt on the shaft first and them roll it onto the brush roller. The other way which I did in my hotel (I had 3 of them) is to pull the brush out, put the belt on the spindle shaft, then onto the roller, the you can stretch the belt with it already in place and lower the roller into place.
The belts are stiff.
I don't have a headphone problem, the recorder plays too slow like the belt is worn where can I get a replacement
Try MCM electronics - they have all size belts and the trick is to replace the stretched out belt with one that is about a quarter to one half inch longer in circumference.
Is there a trick to getting the belt on the motor pulley and brush on the Hoover Elite Supreme
hi ,try warming the belt up in hot water first it will stretch better
Apr 08, 2013 • Vacuums
How to replace pto belt on a 2042 cub cadet
Sounds like you bought the new belt little bit too short. I had that problem and had to take my old belt to compare lengths.
I have a Hotpoint Ultima WT761 Washing machine. The belt has not broken but is damaged and the edge is stripping off. It has come off the drum and motor spindle. Clearly its time to get a new one which I...
not absolutely sure of your exact model, but most washer belts on put on by putting them on the motor the stretching to the tub pulley and holding it there while you move the pulley which then stretches the belt to fit for you.
2answers
I cant move the belt tensioner enough to get belt over alternator pully? Is there a trick?
Put the belt onto all groved pulleys first, then un-tension the tensioner/idler pulley and slide the belt onto it (the tensioner/idler pulley should be smooth with no lip for the belt to go over).
2helpful
2answers
Sweeper belt
Greetings from GoVacuum.com,
Have you replaced the belt with a new one yet? You may want to try replacing the belt, as with flat belts like the Fantom Thunder, they do stretch out 4 -5 inches after time. We in fact recommended replacing a flat belt every year, even if the belt doesn't break, because of the stretching. I think what may have happened, is that your belt is stretched to the point where it will not stay on the pulley as soon as there is any tension (putting the brushes on carpeting), which will cause the belt just to slip off.
You should be able to replace the belt (very inexpensive, we sell Fantom belt for $2) and this should take care of the problem. When you replace the belt, you should also take the roller brush apart and remove any hair, or thread that may be wrapped around the bearings. You should be able to remove the bearing cap by pulling them, or holding one end, and unscrewing the other.
I'd even be willing to send you a free Fantom Thunder belt, if you'd be so kind to vote Fixya for this answer :-) Just send me an email with your name, address, and the exact model number (located on the back of the machine, or the bottom of it) of your vacuum, and vote Fixya, I'll immediately ship you the belt for free!
Please let me know if you have any other questions I can help you with.
Chris Jones
GoVacuum.com
[email protected]
1-866-468-2288
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Top Splendide Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
