That's it.
Those readings are normal. Your meter is working fine.
Car batteries fully charged sit at around 14.4 Volts, Check readings on the battery with another multimeter and then compare with yours - it's possible that there is nothing wrong with your meter
Testimonial: "I think you might be confusing system voltage across the battery when the alternator is putting out a charging current (ie. engine running, which should be around 14.5 volts, and static battery voltage which should be 12.6 volts."
Hi! I had the same problem, I notice the inside 9v battery was low, I replace and start reading correctly.
