System Beep Codes
The Inspironâ„¢ 531 / 531s system can emit a series of beeps during
start-up if the display cannot show errors or problems. These series of
beeps, called beep codes, identify various problems. One possible beep
code consists of repetitive three short beeps. This beep code indicates
the computer encountered a possible system board failure.
The series of beeps has a 3-second delay before it repeats. The
series and delays continually loop until you press the power button.
Code
Description
Suggested Remedy
BIOS ROM checksum in progress or failure
System board failure; covers BIOS corruption or ROM error
No memory modules detected
- If you have two or more memory modules installed, remove the
modules, reinstall one module, and then restart the computer. If the
computer starts normally, reinstall an additional module. Continue until
you have identified a faulty module or reinstalled all modules without
error.
- If available, install a good memory module of the same type into the computer.
- If the problem persists, contact Dell.
Chipset error (North and Southbridge chipset, DMA/IMR/Timer Error for Intel® platform); chipset error
System board failure. Power LED is blinking amber.
Time-Of-Day Clock test failure
Gate A20 failure
Super I/O chip failure
Keyboard controller test failure
RAM read/write failure
- Ensure no special memory module/memory connector placement requirements exist.
- Verify the memory modules you are installing are compatible with the computer.
5
Real time clock failure. Possible battery failure or system board failure.
- Replace the battery.
6
Video BIOS test failure
Video card failure
7
CPU cache test failure
Processor failure
