Auto focus not working properly
SOURCE: Auto focus not working Kodak V803
is the setup shoing that it is on MACRO? if so turn MACRO off
SOURCE: Kodak P880 camera won't autofocus. I bought a used
Hi mfkcolumbus,
Did you check the firmware version? If it's not v. 1.02, then get it at the Kodak support site and flash that firmware to your camera. If it is 1.02, then you may try to reflash that same firmware. Sometimes this helps strait'n out things.
Hope this helps.
Gr. Blackbear
SOURCE: kodak easyshare p880 camera
use WD40 or contactspray around the powerswitch after removing the battery.
then work the switch for a number of times
