What is the resistor R11 (ohms,watts & tolerance) on the control board? Also, Q6 I would like to replace. What is this transistor?
Bonjour,
Nous avons une laveuse Maytag Neptune model MAH40000.
Hors que nous choisissions n'importe lequel cycle de température d'eau (hot - cold, warm - cold, etc.) nous optenons toujours de l'eau bouillante même au rinsage.
Ou croyez-vous est le problème ?
Merci de porter attention à notre demande.
Ronald Clément et Lucie Poudrier
3225, boul. Cournoyer
Sorel-Tracy
450-556-1170
[email protected]
Solution Guy.......I found this very helpful. I'm just starting on may Neptune MAH4000AWW.
Parker, here's a video that may help you...
SOURCE: Maytag Neptune MAH4000AWW
if r 11 is bad you should really check the bearing on the tub you will probably find it to be bad or going bad causing the moter to pull more amps causing r 11 to burn out.
