Nikon D3100 14.2MP Digital SLR Camera with Triple Lens Sports Package with 18-55mm VR Lens & 55-200VR Lens & Nikkor 50mm f/1.8D Manual Focus Lens with SSE 16GB Starters Kit including 0.45x Wide Angle Lens, 2x Telephoto Lens, Filter Kit, Macro Lens Kit, and Logo
A
Anonymous Posted on Dec 01, 2013
Images are black
Whenever i take a picture, the images are black when i try to review them.
Ozzie Morrow Jr.
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Nikon Expert 305 Answers
  • Posted on Aug 21, 2014
Ozzie Morrow Jr.
Nikon Expert
Level 2:
Champion:
Cheetah:
Answers
305
Questions
Helped
65871
Points
398
Did you set your aperture your ISO and speed
please put it in Automatic if you dont know how
Www samsungcamera com
You are either using too slow a shutter speed, or too wide an aperture, causing the images to be overexposed. As to the other issue, the camera may not record images if the exposure is too inaccurate. Try looking in the manual.
Oct 29, 2017 • Cameras
2helpful
2answers
When trying to clear out my camera... there is a black screen & it'll say this picture cannot be deleted when i try to delete. taking up space that i would like to use
Make sure the picture you can't remove isn't locked. When you're in review press menu and make sure that photo isn't set to locked (if so unlock and you should be able to delete it).
If that doesn't help, make sure you copy off all the images on the card you want, as the following instructions are intended to clear the entire card.
After you transfer all the images you want, you'll want to format the memory card. This can be done one of two ways. If you have the appropriate card reader on your PC, you can insert the card, find it in my computer. Then right click it and select format.
The easier way is to use your camera's format feature. I don't have that specific model, but it can usually either be found in menu, or by pressing the picture review button and then menu. Formatting the card should erase all the data on it and clear off the picture you don't want.
Please leave feedback if this was helpful. Thanks.
1helpful
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
I HAVE A PROBLEM W/ THE LENS OF MY KODAK EASYSHAREDX4530.WHENEVER I TRY TO TAKE PICTURE WE CANT SEE THE IMAGE ON THE SCREEN
Ok not sure if you mean whilst taking the picture or after, if this is whilst you need to select the picture mode i.e Auto, Sport, Night, etc, the camera will display the config on the screen for a few seconds, in this time hit the OK button this will set the picture to Liveview, you will be able to see them on the screen,
Now to see the pictures you have taken you need to push the review button and scroll through the images,
Let me know if this helps if not i will look into it more for you.
Jan 12, 2010 • Cameras
LCD is black
you can see images clearly? but no Menu items show is that what you mean? This would indicate a firmware malfunction. If you see nothing at all on the screen but only 'ghost' images then the back light has blown. Try first of all with the camera on tapping gently at the base of the casing in the region of the screen- this is where the connectors to the main board are. Contact The Minolta support team. If you are getting nowhere - I suggest the next camera - repairs are not usually an economic option if at all.
2answers
No images
same old problem of damaged CCD. Get the CCD replaced.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
