Washe shuts off randomly after it fills in all the different cycles. I have to open and close lid to start it again
SOURCE: Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
SOURCE: Have to slam the lid
The same thing happened here. It turned out to be the lid switch. It
can be accessed by taking off the back plate (behind the controls) by
unscrewing three screws and two screw bolts -simple.
I removed
the lid switch and tested it with an ohm meter - instructions are on
this site. You should have continuity across machine-motor, as well as
across machine -line. (These are labeled on the switch).
If you
don't have a meter and you still want to see if that's the problem,
after you have removed the lid switch, short the machine and line
connectors, (you'll see these labeled on the lid switch so you'll be
able to figure out which wires go with what) as well as shorting the
machine and motor connectors. Both of these need to be shorted. That
bypasses the switch and will activate the motor and controls.
That's
what I did to confirm that it was all a "lid switch " problem. I
ordered a lid switch from this site for $24.95 for the repair, and will
use the "shorting process" to do a couple of loads of wash as I wait
three days to get the switch. Good luck.
SOURCE: Washing machine it shuts down water filling cycle
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
SOURCE: Need some help!
sounds like the lid open switch got stuck..check that with a chopstick or something like that, to ensure that it's not stuck. won't run if that switch is stuck in 'open ' position.
SOURCE: maytag top load washer won't pump water out=intermittent problem
If your lid switch was the problem I dont think (and I might be wrong) that it would spin in the first place.
Your pump may have a separate belt and it could be loose or worn out but this is on older models. The pump may not be turning or turning and not pumping. The pulley may be turning on the shaft and its not pumping. Give it a
spin and see if you see it turning inside. If not replace it.
The motor and timmer sounds good because of the "spin" you discribed. So we are left with the pump or a filter if it has one.
Look in the lower section find the pump front right hand corner I believe. Trace the hose back up to the tub above nothing in between and you have eliminated the filter. I filter could be any shape but will either attach with 2 hoses or 1 hose and attached to the side or bottom of the outer tub.
I think your pump is probably stopped up, strings and lint especially if you have some older rugs, towels, and rags that are shedding or coming apart. You can try and clean it pretty easily Unplug. Then remove it and look inside it. Catch all the water you can and keep another towel close by. Examine the water. Looking for lint and the like. If its pretty clean looking and not turning freely look for signs of something wrapped up inside it.
Hope this helps. Please rate me accordingly and good luck.
