I have a infinity Entra sub 150watts 10 inch. it comes on in plays. but when the bass gets ready to hit real hard cuts out
As from your description it sounds that you run your system on maximum volume.Yes.Well some amplifiers have protection circuits build into the design to protect both the speakers and the amp from failing(blowing up) their are different ways of doing that but i think the most common are thermall protection. Thus i recommend keep below the limits to be on the safe side.And protect your investment.
SOURCE: inifinity 1252w subwoofer
this is probably due to the box they are in. it seams that your box is tuned to a lower freq then the bass hits that are popping. message me with the box dimensions and the speaker parameters
SOURCE: Infinity Bass link keeps cutting out.
Tapping into front or rear gets high level signal 3 plus volts at low impedance which is totally unsuitable for the sub's line level input which is more like 300millivolts > A competent tech could make up an attenuator patch or just take it to a professional car installer before you do more damage
ataraxia
