2010toyotatundra powerlocks and powerwindowsdo not work
fuse blown.
check fuses.
some cars have circuit breakers on window motors.
if one motor shorts the breaker pops but then resets.
i use a voltmeter to find lost power feed.
its easy.
check voltage to motor, got 12v , when active (swith closed?)
no, then check at the switch, got 12v at switch input and output
with switch active,
yes, then wire is cut from switch to dead motor.
no, then wire is cut from input to switch and fuse.
like that. its not hard at all to use any voltmeter even a $10 meter at walfart.
