SOURCE: Kenmore washer model 417
most time on kenmore washers any of them the lid switch goes bad you can replace it or bypass it,let me know-mike
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: Kenmore HE2 Frontload Washer will Not go into spin cycle
Could be that you have something in the pump. Remove the bottom panel by removing 3 screws and you will see a round cap facing you in the center of the washer at the bottom. there will be alot of excess water behind this cap so get ready with plenty of towels. Unscrew the cap as you would the gas cap on your car and all the water in the lines and in the machine will come out here. Inside here you may find a number of things. Some of the things I have pulled from them are ...coins, socks, pencils, underwear, underwires to bras. The list goes on and on. Or you may not be using "he" detergent. Use only "he" powder detergent. Use vegetable oil to remove excessive sudds build up then use 2 cups of vinegar to clean the machine on whitest whites seting.
