Microsoft Surface RT Logo
L
Lisa Posted on Dec 02, 2013
Problem with a box i can't clear
I have a box that looks like a themomtor and it won't go away... when I touch it, it just start back at 1 and goes to 100 and stays there??? It won't let me go into some of my settings either.
Darrell Turner
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 02, 2013
Darrell Turner
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
1261
Points
9
The thermometer indicates that the tablet is overheating. Turn it off until it cools down, 20-30 minutes.
My tablet shut off while still charged and will not come back on, any help?
Hi Queenfrog, The link below is a youtube video showing you how to fix your tablet, There's video's down the right side you can check out as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
My android dual core jelly bean box is stuck on the start screen
Press the reset button using a paper clip. Look for a tiny hole usually on the back or side of the tablet.
My tablet toshiba excite pure is saying Unfortunetly, sysyem UI has stopped. It goes off when i push ok and comes right back. How do i remove it?
Have you tried to wipe the cache partition
App data
Step 1 Press the "Menu" button and tap "Settings." Touch "Applications."
Step 2
Tap "Manage Applications," select the "All" tab and touch an application name.
Step 3
Touch the "Clear Data" button to wipe the app's saved data. Tap "Clear Cache" to remove any cached data for the app.
Phone Data
Step 1 Turn off your Android device. Reboot the phone or tablet into Recovery Mode. The process is specific to the device model. For the Motorola Droid, press and hold the "Power" button and the "X" key on the slideout keyboard. Release the "Power" button when the Motorola icon appears. Press the "Volume-up" and "Camera" buttons simultaneously to open the Recovery Console. To access Recovery Mode with the LG Ally, press and hold the "Power," "Home" and "Volume" buttons simultaneously.
Step 2
Press the "Volume-down" button to scroll to "Wipe Data/Factory Reset." Press the "Camera" button to select it.
Step 3
Scroll to and select "Wipe Cache Partition."
Step 4
Highlight and select "Reboot System Now."
1helpful
2answers
How do I clear my kindle
Bring down the top menu and touch the "more" selection. Touch Device. At the bottom of this list you will see "Reset to Factory Defaults"-touch that option. You will get a warning box. Touch Yes. This will remove all personal data from the device.
How do you set tablet to static IP?
If you have Android 3.x, use this procedure:
1)Open Settings
2)Touch Wireless & networks on the left
3)Touch Wi-Fi settings
4)Find the network you wish to connect to and long press it (touch and hold).
5)Touch Modify Network
6)Touch the IP Settings drop down and change from DHCP to Static
7)Enter the settings for your network - if you are unsure what settings to use, contact your network administrator
If you are using Android 4.0, then use this procedure:
1)Open Settings
2)Under the Wireless & networks heading on the left, Touch Wi-Fi
3)Find the network you wish to connect to and long press it (touch and hold).
4)Touch Modify Network
5)Touch the Show Advanced Settings check box in the lower left corner of the dialogue box. If the Show Advanced Settings option is not displayed, you may need to go back a step and Touch Forget Network, and then, when you reset up the network, you will see the Show Advanced Settings option
To ensure that you have got Static IP visit IP-Details.com to have an IP lookup.
HOW I FIXMY VIVORT
Hi, This is a problem in the BIOS my advice to you is get in touch straight away as you will always have problems! unless they are prepared to walk you through the settings in the BIOS. Be a happy PC owner & get this exchanged free of everything they should exchange the PC without any problems & they will pick up the present PC when they deliver the new one to you. I must add the blue screen is another problem with the Video card, Hence stick out for an exchanged PC it's their liability. Please leave me feed back: Malcolm Campbell, Thanks.
Cruz tablet- web pages won't load
Search on google, search comes up but then won't go to web page, goes right back to the search page.
I have a Toshiba tablet M780-s7230 and i tried reinstalling the touch screen driver and my tablet pen and touch screen still don't work what else could i do?
Have you turned on the Touch feature on Windows 7 yet? That could be the reason why your touch screen feature is not working.
To turn it on please follow this:
1. Open your Start menu and type "Touch" into the search bar. This will show a variety of options, including the "Pen and Touch" options. Double-click it to open the "Pen and Touch" window.
2. Check the boxes next to the "Use your finger as an input device" and, if preferred, check the "Enable multi-touch gestures and inking" box as well.
3. Click "Apply" to set the options and click "OK" to exit the window.
Hope this helps!
Top Microsoft Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
