Industrial Juki sewing machine 8500 is what I have and upper thread tension dial popped out and does not stay in. All the parts seems to be present but not sure. The spring inside is intact and tension dial parts are still attached to the dial.
SOURCE: I own a Juki DDL-8300N industrial sewing machine,
Hi, Please accept the solution if it's helpful. Do get back to us for any further query. Thanks for contacting fixya.com
I do understand sometimes the manuals do not give a complete picture. Check out these videos that I have posted bellow. They show how to set it up.
http://vimeo.com/14428186
SOURCE: the thread on my Juki machine keeps breaking when
there's a tension dial with numbers-0-9 --above the needle area- the smaller the number the looser the tension--the higher the number the tighter the tension
thread breaking-try this
try rethreading the machine
thread tension to tight
needle is bent or blunt
needle is inserted incorrectly
the thread is either too heavy or too fine for the needle
try this & see if it helps you
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
SOURCE: hi there JUKI DDL 8500-7
hi there
can you explain what is the problem exactlly? if the problem how to opne presser foot function tell me control box model or email me.
Best Regards
ashraf abozid
[email protected]
SOURCE: how do you reset the
HI THERE
CONCERN HOW TO RESET. THERE ARE MANY TYPE FOR CONTROL BOX WITH THAT MODEL.
1-SC500/510 CONTROL ( PRESS -- key and + key and down arrow key and power ON , it will appear rs on panel ) control back to factory set.
2-SC810/sc910N control ( press -- key and + key and left arrow key with power ON , it will appera rs on panel) control back to factory set.
if need any information please ask or mail me ( [email protected] )
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
SOURCE: I need information on tension disk for Juki 1541-S Walking Food Industrial Sewing Machine
Get a magnifying glass and look carefully at the disc for a build up of wax and burrs. You may need to clean them up or use a piece of fine sand paper to remove burrs. Start there.... then if no improvement seek out your local industrial sewing machine repairman to get parts and further help.
